horrocks007
Following up on this, as the parts from Metalcloak came in and were installed. For this if you doing this yourself, it helps a lot if you have a pickle fork to get the upper drag link unstuck from the pitman arm.
Comparing the Metalcloak hardware to the Synergy, both are beefy and well built. The Metalcloak is zinc coated and is designed differently. Time will tell if the zinc coating will hold up, vs the powder coat on the synergy. The biggest difference I see it that the design of both the OEM and the Synergy use a pinch bolt type mechanism that has an open seam. The nice thing about the seam is that you can pry it open, to free up the adjuster sleeve, either located on outside (OEM) or inside (Synergy) the drag link or tie rod bar. The downside to these seams is that they are like open wounds being pounded with salt grime and mud from various jeeping adventures and daily driving. I think these seams are hard to clean out and have lead to my problems.
I personally would avoid these kind of pinch bolt seams used in the OEM and Synergy parts. In my opinion they are a poor design for us Northerner rust prone states.
![IMG_1478293365.887674.jpg IMG_1478293365.887674.jpg](https://www.wayalife.com/data/attachments/210/210233-9dd25bf4e236ed572483ee1aa4581ead.jpg)
![IMG_1478293379.374997.jpg IMG_1478293379.374997.jpg](https://www.wayalife.com/data/attachments/210/210245-c3ff693aa2613600c0d7524de9805824.jpg)
Metalcloak win for me!
